Ver 3.0.0 rescue test
latjo-k
hi
I whas not sure if my units works in rescue mode whith ver 3.0.0,so i did a test like this.
i let the unit start up normal, set the cp to 42% Went araound with the heli did loops and rols flips or so
at about 2min.Then i held the heli upside down and whatch the swashplate,hit the rescue sw.
Swashplate Went to -cp(climb up) and then tilts to the right(rollover).
So now iam quite sure that rescue works in real flight.
Thanks Tomas and Spirit team
yes, this is good test. With version 3 it is possible to do similar tests for unlimited time. Swashplate should work in the same way as in the flight.
