Does the Spirit Pro have inbuilt regulator
Moby58
Hi Guys,
The Spirit Pro can have an input up to 15v on AUX1.
Is this regulated down to 5v or 6v before going to the servos?
Or is it just passed thru untouched?
Moby
Upside down, down under in Oz
10x
The input is on the same bus as the servo's, so 12v in, 12v out...
Moby58
10x wrote:The input is on the same bus as the servo's, so 12v in, 12v out...
ok, thanks for that :-)
Moby
It has built-in regulator, but not for the servos.
Moby58
ZeXx86 wrote:It has built-in regulator, but not for the servos.
Thats a bummer :(
Moby
urgno
Moby58 wrote:Thats a bummer :(
that's not a bummer, is a flybarless
what you are looking for is called BEC/SBEC/UBEC :-)
Moby58
What I mean no point having a 15v input if it is just going to burn out the servos
Moby
thestructured
At least it won't burn the unit at the same time :lol:
HeliMLM
there are good tests out there regarding reverse current generated by servos... induction voltage being up to almost 15v... so good to be safe on Spirit side. the unit is protected of being damaged (less likely - short peaks only) but most important: protected of malfunction (crash/reboot in flight?) as it is proof against peaks of up to 15v. brownouts / malfunction due to reverse current is a well documented problem...
... and maybe some day in the future we will see shv-servos (Super HV)... i.e. 12V or even 15V ;) great to be prepared!
cheers
Michael
Kluftinger
What would be the advantage of a HV Power supply for a Spirit unit with 6V Servos connected to it, protected by a regulator?
For scale helicopter I need to configure my system the other way around.
I'm using 8.4V HV Servos for swash plate and tail rotor, but for a retractable landing gear I want to use 6V standard servos.
A Y-connetor and a BEC takes care of the 6V servos in an extra voltage branch.
