Today I tried to install my new GEOLINK-modul.
In the beginning everything seems to be okay.
Then I tried the calibration-process.
This could not really be finished. I don't no why ?
Therefor I would like to "reset" the GEOLINK-modul
via making an firmware-update.
There are two methods to update...
I tried the "Wiederherstellungsmodus".
After reaching the end (bar with 100%) an fault-message occurs:
"Update fehlgeschlagen".
What went wrong ?
Hopefully there is now Hardware-defect (Flash-memory).
What can I do ?
Thanks for help
Geolink Firmware-Update fails
until you finish the calibration process geolink is almost dead
maybe this video can suggest you the movements you have to do with gelink to finish calibration
of course this has to be done outside
https://www.youtube.com/watch?v=skH0u2yV6_M
...still problems.
I did the movements with the GEOlink-modul as in the video to be seen.
But it will not be finished.
How is the correct finish-state indicated ?
When I checked the settings with my notebook from the modul I only see the
"Information" and "Aktualisierungs" - tab.
Today was the first flight with my new TREX700X GPS-controlled !
I used Stabi-mode "Coax" and GPS-features "Position Hold" and "Altitude Hold"
Everything works fine...
The BT-modul was still connected to SPIRIT2 during flight.
Is that ok or may be a risc ?
I'm pleased of the new features that will come.
Thanks for help.
Achim
Thanks for help.
Achim
