Any known date for a new version 3 release ?
enied
I would like to know if there is a known release date for a new version 3 release. RC flying will be possible again in my region starting at May 1st. So, better wait for the new release or downgrade the flying helicopters from 3.0.1 to 2.8.0 ?
Thank you in advance for your feedback.
Best Regards,
Eugen
enied
due to the lack of any feedback I needed to revert to 2.8.0 on the Spirits and 1.0.3 on the Geolinks. Be careful when you do, not all settings will be carried over, so checking and correcting the 2.8.0 values is mandatory after this downgrade.
Best Regards,
Eugen
for sure it will take at least one week.
No need to change any value, only load it from backup. All settings are preserved when updating from 2.8 to 3.0 and back.
When you will do some changes in 3.0 then loading from backup file is required (after downgrade).
It is only very important to not use old 1.3.2 firmware. This will cause issues.
enied
Hi Tomas,
thank you for your feedback. I am looking forward to the new resease.
BR Eugen
bad3gakk
Can you revert the android app version while youre working on it?
I cant connect to my copter, error says app v 3.0.x not compatible with firmware v 2.8.x :(
enied
bad3gakk wrote:Can you revert the android app version while youre working on it?
http://spirit-system.com/phpBB3/viewtop ... =20&t=3898
BR Eugen
