ESC off in fail safe as standard
flydown
isn't it possible that the Spirit sets the ESC standard to off in the event
of loss of reception? The FBL knows where the ESC is located., so it should not be that problem.
That would be great for people like me, you should try something more often, but set fail safe right, before the heli flies away recently like my beautyful Protos 380.
Many regards
Uwe
of course, this is possible.
It is enough to click at the Set Failsafe button in the Channels window with Throttle at Hold position.
You can simply try it by turning your radio off.
