Support for Ubuntu 20.04
eraserix
I recently upgraded my system to Ubuntu 20.04. Apparently, Ubuntu no longer provides Qt4, which makes it impossible to start the Spirit configuration software (3.0.0). (Qt4 was dropped from Debian: https://bugs.debian.org/cgi-bin/bugrepo ... bug=953294)
Code: Select all
$ ./settings.sh
./settings-x86_64: error while loading shared libraries: libQtGui.so.4: cannot open shared object file: No such file or directory
$ ldd settings-x86_64        ✘
	linux-vdso.so.1 (0x00007ffed3bcb000)
	libQtGui.so.4 => not found
	libQtNetwork.so.4 => not found
	libQtCore.so.4 => not found
	libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f1a1bcb2000)
	libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f1a1bad1000)
	libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f1a1b982000)
	libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f1a1b965000)
	libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f1a1b773000)
	/lib64/ld-linux-x86-64.so.2 (0x00007f1a1bcec000)
Thanks for the report.
It will be fixed very shortly for upcoming new 3.0 version.
tysonfromcanada
Hi guys, I installed qt4 on my ubuntu 20.04 and the tool works fine now. Found the instructions below:
https://askubuntu.com/questions/1234786 ... untu-20-04
no need to install anything. Just start: settings.sh script and everything should work.
tysonfromcanada
I kept getting an error until I installed the qt4 libraries.. fairly fresh default installation from a couple of days ago. Any idea what else I could have been doing wrong?
eraserix
It works on my Ubuntu 20.04 installation. I had to install libaudio2, but nothing more. Qt4 is bundled with the Spirit software, so no PPA required.
Thanks for the report. What error are you getting when starting the software?
