Taranis integration - gyro not disabled
jjuk
Using the taranis integration.
When adjusting the servo subtrim, the gyro is not disabled so heli must be perfectly level to perform this adjustment. Can you disable the gyro here like when using the PC software? ( maybe add a tickbox "disable gyro" in the integration? )
Serenus
you can overwrite the value by a switch.
