LIMITED SUPPORT
We are working very hard to finish version 3.0 as fast as possible.
For this reason please allow us longer time for replying to your questions.
We expect to finish new version in approximately week.
urgno
thank you and take your time Tomáš ;)
flydown
If it takes longer, that's the way it is. The main thing is that it will be good.
Greets Uwe
Milindur
I am looking forward to v3.0, the enhanced Jeti integration and the upcoming Spirit RS. Take your time!
And btw., thank you very much for the great product. I build my first heli about two weeks ago, installed and configured the Spirit 2. The bird flies really great and without issues. At least when hovering (sometimes already in manual mode) or when doing a bit of cruising (only possible thanks to the stabilization mode).
passe partout
A big thank you for the work done, and for the transparency, it is nothing to wait when you know the work done.
mb-1953
Been a few weeks, are you any closer to completing the 3.0?
Yes, if last few tests will be finished without any issue over the weekend, we will be releasing on monday.
The new version will be 3.1 since there are additional improvements.
If this will happen we will be shipping also Spirit RS and new radios during next week.
Rocala
Hi Tomas,
Just few remarks about your system ...
We have no parameters to specify where is the Controler ... (x, y, z from the CG)
We have no parameters to specify where is the GeoLink ... (x, y, z from the CG)
How can your system work without these different values ​​for EACH installation ?
Both modules have parameter called Mounting Position.
urgno
