[Solved] Down grade from 3.0 to 2.8 new Spirit unit
yufasa
So I just received a Spirit Red and downloaded Spirit-setting 2.8.
When I connect the FBL I get a message informing me that there is a version mismatch and I need to fix it...the Spirit unit has 3.0 on it!
The problem is that I cannot find spirit-setting 3.0 as apparently this is required to downgrade the firmware.
I tried to use the "recover mode" and it will not show my any firmware files so I guess the 2.8 software does not like something with higher firmware?
I tried to find a copy but been unsuccessful so far.
Note that configuration is disabled so I can do nothing with my new FBL until I match the app with the firmware.
if you downloaded Spirit Settings 2.8 recently you can downgrade Spirit firmware directly without any issue.
Just select 4df firmware file at the Update tab and press the Flash button.
yufasa
Thank you I got it sorted out and everything is working as far as I can tell. If everything goes well I will try flying this weekend....
