Linking Horus x12s & X8R with spirit 2
Posted: Fri 15. May 2020 22:41:35
by Neilsteers
I have been trying for days to set up my Horus 12s (fros not open tx)and X8R to the spirit 2.i have connect cables as per the setup manual using S-BUS but none of the channels match in the mapping: could someone Provide pictures or a wiring diagram that a simpleton like me can follow I.e output mapping in the tx and screenshots of the spirit setup
Re: Linking Horus x12s & X8R with spirit 2
Posted: Sat 16. May 2020 11:37:31
no need to change wiring. Only to reset your radio profile to default.
Then everything should be OK.
Please use our OpenTX profile (if you have OpenTX).
In radio it is important to set correct channel layout. There are several options (AETR/RTEA).
So if it is not working well then switch it to the other one - all the mapping should be OK then.
