Spektrum Integration page opens again (Closing not possible)
Clarion_Power
This happens many times now so i want to ask if its normal.
When i open the integration page after a flight, i change a value (for example feed forward), safe it and leave the integration page by holding the 2 sticks together. Then its closing the menu and directly reopening again. So i have to unplug the battery if i want to continue flying.
Bank 2 was selected by the transmitter and i did the changes in the same bank.
Last Spirit software and spektrum software is installed.
Unfortunately we can't reproduce the issue.
What is your setup? Please describe everything you can.
Spirit unit must stop flashing when you will close the settings. Only then it is really closed.
So probably you are not holding sticks together long enough.
Clarion_Power
Sorry for the less informations ;-)
Spektrum DX9 (actual software)
SPM 4651t
Spirit 2 (actual software)
I can hold the sticks as long as i want. After moving the sticks to the edge, the message (Close) is shown in the dx9 and directly after that the integration page is open (ready) again and i can go into the parameter settings and can do changes.
If you want, i can create a video where you can see the screen of my dx9.
raemin
Same issue for me if I pull the stick "to hard". By contrast if I activate the menu without "bending" the stick, all fine. I presume that if there is a bit of play on the gimball, the stick goes past 100% (ex: 102%) and when it return to 100% this triggers the menu again?
Anyhow, I've noticed that all the stick inputs do not require to "bend the stick", a moderate deflection is enough to perform all operations.
Hope this helps...
