Henseleit TDS
Posted: Fri 05. Jun 2020 22:25:09
Just finishing up the set up. This heli uses trailing edge control of the blades. The swash moves downward to achieve positive pitch. After set up, I see on the advanced tab that I can check a box for trailing edge control. When I did that I had to reverse the directions of the pitch, elevator and aileron servos. When I move the helicopter around it seem as though the correction is opposite of what it should be. If I tilt the nose down, I believe the correction response would be to lower the pitch and aileron and raise the elevator servos. (opposite of a conventional helicopter). I can only get this if I "uncheck" the box, and go back to the original servo reverses. Hope this makes sense?
