Trouble getting recorded vibe logs.
xoexoe
I can’t seem to view the recorded vibe log. Can some check if I’m missing a step?
I set a switch on my transmitter to control F: Spektrum Analysis Y. In my Spirit’s Channels panel I can see the channel (12) activate from Off to On, so I know the switch and channel are okay.
Now during flight in a hover I activate the switch then deactivate it. After landing I keep the flight pack attached and plug in the micro Spirit into my laptop and open up Spirit Settings. It connects just fine, but when I go to Diagnostic —> Spektrum Analysis there are only the usual 3 options for live logging in the drop down, not recorded logging.
I also tried keeping the transmitter switch in the on position just to see, but that didn’t help either.
Any ideas?
Micro Spirit 3.1.0
FrSky Horus X10S OpenTX 2.3.5
Find me on HeliFreak, username Xoexoe
xoexoe
Bump.
yufasa
Not sure how you go about it, but I turn on logging in my DS-14 so now I can see the vibration right on my radio after the flight as it is part of my flight log and if I remember you you Jeti too?
xoexoe
No, not Jeti. I’m on Horus X10S OpenTX.
Tomas, any insight? Am I clicking and doing things in the right order?
blarks
xoexoe wrote:No, not Jeti. I’m on Horus X10S OpenTX.
Did you solve it xo?
xoexoe
No. I recently PMed Tomas. Hopefully by Monday or Tuesday.
blarks
xoexoe wrote:No. I recently PMed Tomas. Hopefully by Monday or Tuesday.
Never messed with it until now so you probably know more than me, but I just looked and there is an in flight option in my drop down list in addition to the 3 axis, you have this as well?
xoexoe
No, I don’t have that option when I checked. That seems to the thread hurdle I have.
Thanks for checking!
first from all you have to select F: Spektrum Analysis X/Y/Z.
From that moment you have to see In-Flight option when you will open Spektrum Analysis in the Spirit Settings.
Is this the case?
If yes, just save the settings and it must be visible anytime later.
During flight just engage assigned switch and then open the analysis and select In-Flight.
That is all you have to do.
cracked canopy
Im having the same issue select F:Vibration Y and assign channel.
Then go to the analyzer but do not see In Flight as an option.
If I do this in demo mode the In Flight shows up as an option
