Replace Spirit 2 with Spirit RS - copy settings over?
Posted: Sat 06. Jun 2020 14:35:13
by Fortune7
I have a well-adjusted Spirit2 on a Trex 700X and am removing it to install a Spirit RS. The Spirit 2 already has a new home to go to.. :D
If I backup the Spirit2 settings and import them to the 'RS, what do I need to check / adjust for the new setup?
Am I correct to assume:
1. It is necessary to go through the setup wizard for servo adjustments, etc?
2. I can use the Jeti - DS12 transmitter settings from before, just re-bind to the 'RS?
Can I use imported settings for gains, stabi, banks, etc.?
Of course I can write-down all settings from the Spirit2 and transfer them to the 'RS, but I'm asking if there's a quicker (safe) way.
Many thanks,
Andy
Re: Replace Spirit 2 with Spirit RS - copy settings over?
Posted: Sat 06. Jun 2020 14:51:28
by jjuk
I'm not sure of the answer, and I'm interested to know if settings can be down/uploaded to different model spirits (red to pro, red to s2, etc.)
I assumed it couldn't be done last time I needed to do this (spirit red to spirit 2) so I took screen shots and did it manually.
The flight performance was also slightly different so I needed to tweak the setup anyway, but was in the right ballpark.
The d4s online viewer didn't support v2.8 so couldn't use that.
A 'compare D4S' screen in the software that supported all versions would be very helpful (hint Tomas [emoji57]).
Posted: Sat 06. Jun 2020 20:09:15
by FrankFuss
jjuk wrote:The d4s online viewer didn't support v2.8 so couldn't use that.
There is a way to display version 2.8.0 and 3.1.0 profiles. You must load the profile 4ds file it into a version 2.7.1 Spirit Settings application in demo mode, create a new profile 4ds file and then upload that one.
Posted: Sat 06. Jun 2020 20:16:04
Everything should work immediately after loading settings from other unit.
Posted: Sat 06. Jun 2020 20:19:30
by jjuk
ZeXx86 wrote:Everything should work immediately after loading settings from other unit.
So settings from any unit type can be loaded into any different unit type? Eg I can load spirit pro settings into a spirit red?
