Latency Spirit2/Rex 3 vs. Spirit RS
Till
can you tell us something about latency ?
Is there a advantage for the spirit rs compared to the spirit 2 with rex 3 ? The overall latency from moving the transmitter stick to see a movement on the servo arm should be abount 20ms - has the spirit rs an advantage here - so how can we imagine the internal connection between receiver and spirit ?
Thank you for a little technical insight into the development - so far i am very impressed from the new RS :-)
Best regards
Till
latency can be up to 5ms. In the worst case 10ms.
Latency is not given usually by receiver connection, but by RF protocol which is not related to FBL or any part between receiver and fbl.
Latency is same between RS and external receiver. There is nothing that could make it worse.
