Confirm wiring with Spirit 2
Pking
am building a OX4 MAX with all the components Spirit can provide
-Spirit 2
-Geolink
-Telemetry
-Spektrum SPM4649T
-DMSX
-WiFi-Link
I put all the components in a document with the intended wiring and can You confirm it is OK ?
One big question is the SPM4649T and the DSMX receiver, can they use the Spektrum multi adapter because all the other ports are occupied ?
http://cloud.tapatalk.com/s/5ede4f93377 ... 20heli.pdf
Thank !
Envoyé de mon iPad en utilisant Tapatalk
Pking
Bump,
Thomas, i have a order for spirit 2 paid for and waiting, I think I put all the right wires etc.. can you confirm the connections will work ? It’s mostly the receiver I am not sure, I don’t have a srxl receiver at the moment.
instead of Spektrum Multi Adapter I recommend to use Spektrum Adapter V2. But you can still use Multi Adapter, just by 50%. For second satellite connector will be unused.
Wiring looks good.
Pking
ZeXx86 wrote:Hi,
Wiring looks good.
Thanks Thomas,
I want to connect the SPM 4649T and a dsmx satellite, i don’t a way to connect them with the 2 ports taken by telemetry and Geolink.
That’s why i chose the Multi Adapter. Is they’re another place i can connect the 4649T or the satellite but i would need 2 Spektrum adaptateur V2
Thanks !
with Spektrum Multi Adapter you can connect only usual Spektrum satellites, not SPM4649T.
Both have very different wiring and connectors.
So Spektrum Adapter or Spektrum Multi Adapter are not compatible with SPM4649T. They are actually not needed. Instead JETI Integration cable can be used with this receiver.
See this page:
http://manual.spirit-system.com/index.p ... e=SPM4649T
Pking
ZeXx86 wrote:Hello,
See this page:
Thanks Thomas,
If the 2 side ports have telemetry and geolink connected
And I connect a 4649T on the ELE/PIT/TAIL and RUD port.
Where do I connect the satellite ?
It says I can have 4649 + satellites:
« 1 Spektrum satellites (optional)
To improve receiving capabilities you can connect additional Spektrum satellites. So the combination can be following:
Spirit 2 - 1x SPM4649T + 0-2x Spektrum satellites »
Thanks for the help.
The satellite (Spektrum Adapter) will be connected at the RUD port. But you will have to use Y-cable for the RUD port. Or you can power the SPM4649T from other free port - this is more safe.
