Spirit 2 and opti-guard, no ports left
Posted: Fri 12. Jun 2020 16:00:27
by Jay23
I swapped my spirit pro for a spirit 2 on my Goblin Drake, I'm using the telemetry as I did on the pro but the spirit 2 has 1 less port so I can no longer use my opti-guard.
Is there a work around so I can use my opti-guard even though all other ports are used up?
Re: Spirit 2 and opti-guard, no ports left
Posted: Fri 12. Jun 2020 16:17:20
by FrankFuss
You can use a Y-cable to have the opti-guard and one of the servos or the receiver share a port on the Spirit 2.
https://store.spirit-system.com/en/acce ... cable.html
I wouldn't connect the opti-guard to the receiver instead of the Spirit. It should provide power directly to the Spirit.
Posted: Fri 12. Jun 2020 16:21:02
by Fortune7
Jay23 wrote:Hello,
I used a servo Y cable connected at AUX1 (or I believe any port except SYS or ELE/PIT/AIL). Then the BEC (or supply) connects to the Y as well as the Optiguard. The Y connector is double-sided-taped to the outside frame to be accessible, then when bench testing I unplug the Optiguard and connect a separate 2S battery, to prevent having a main (12s) battery connected. I get mine from Tomas @ Spirit (German made), the Y cable needs to be good quality.
Cheers, Andy
PS Frank beat me to it - what he said!
Posted: Sat 13. Jun 2020 9:52:27
by Jay23
Thanks all for the responses I'll go with the y cable on the bec.
Posted: Sat 13. Jun 2020 11:29:52
by Planehazza
It's critical the opti guard provides power to BOTH rx and spirit, otherwise its pointless. The FrSky integration cable (needed because I'm using telemetry) doesn't carry power so I've got a cable running from the rx to the Spirit (with the data pin removed)
I'm going to try and document it later today.
Posted: Sat 13. Jun 2020 12:34:29
by Jay23
Thanks, I don't use and Rx just the telemetry unit and a dsmx sat.
