TDSF with Spirit RS
Puttputtmaru
Does anyone have a TDSF set up for Spirit? I have looked at this forum but have not seen any specific set up
It is such a light Heli that I am not sure what to use.
My TDSF is with the suggested set up by Henseleit:
MKS mini servos HV 9767 and HV 9780
Pyro 400-10
Kolibri 90 LV
If you have any done set up or any advice as to what I should be most likely to have to modify compared to a « regular » weight 700 I would appreciate.
Thamks
helijürgen
TDR einstellung kann man nehmen und Heckempfindlichkeit anpassen.
Gruß Jürgen
Puttputtmaru
helijürgen wrote:TDR einstellung kann man nehmen und Heckempfindlichkeit anpassen.
Gruß Jürgen
That was the plan but I would like to have more information if at all possible.
Thomas has mentioned that the 6 degree might be a problem in one old thread here but with no indication more????
Gerrybru
I took my TDF settings and adjusted only the servo settings and the 6°.
It fitted perfectly when flying in, I just had to adjust the sensitivity a bit.
Puttputtmaru
Gerrybru wrote:I took my TDF settings and adjusted only the servo settings and the 6°.
Would you mind sharing your values?
Puttputtmaru
I just want to thank Gerrybru for sending me his settings.
I successfully maiden my TDSF and it flies perfectly with my Spirit.
Timo Wendtland have nice setup for TDSF.
I will try to share it.
Puttputtmaru
ZeXx86 wrote:Hello,
Please do this would be interesting to see and compare with the one I have right now.
if only it could make me fly like him :shock:
