Sent from my Redmi Note 7 using Tapatalk
The yellow wire is rpm out.. I'm trying to get mah consumed.. so I can fly of the mah and not a timer..yufasa wrote:Move that yellow wire to the middle position of the connector and then plug it into the “Ele/Pit/Ail” port on the Spirit 2
The Brown/Red wire can be plugged into Aux2 as a Power supply (BEC) but is not needed if you use Aux1 as the throttle, unless of course you left your throttle on your receiver then you do need to connect it.
Yes I have it all working now, using the cable from spirit plugged into the programming port on the ESC.. so the cables I showed in my pictures are just not needed on the ESC. I have just cable tied them all up under the Heli.
