[SOLVED] Stabi correction
latjo-k
Hi
If i check the box stabi correction in advanced expert settings,and then Close the settings program and open
it again,the box is empty,am i doing somthing wrong or is there Another explaination?
Ver 3.1 Spirit pro.
Anyway this ver. is great.
the unit detected that sensor part required for the Stabi correction is not working properly.
Did you perform calibration with version 3.0.0 or 3.1.0?
Rescue performance will be not as good as normally if sensor is really not OK, but will be better than with 2.8.
This mean performance could be little bit worse even with Stabi Correction off.
But firmware 3.1.0 can operate normally in any case.
In the worst case we can replace sensor in the unit for free.
latjo-k
Hi
Yes i did perform sensor calib in ver3.0,and the resque didint work at all.
i Went back to ver2.8 and it works well.I havent done calib in ver3.1 but the resque seems to be good.
I expecting the new unit RS in next week,than i can send the pro back to you.
thanks
Then it is just possibly the calibration is not good and should be made again.
I will send you PM.
Problem was resolved. The issue was due to a calibration.
