I programmed RTH at 50% so it auto detects the right position when it’s turned on and on the same channel the Altitude Hold on a uSpirit
The objective is to the RTH on and Altitude hold with the pitch movement allowed so I can adjust the altitude while the heli is coming back and remove my hand from the sticks.
I tried and when I turn on everything, the pitch does not move at 50% for both channels it’s move at the beginning and then stops moving.
When i did the configuration on the spirit Menu in Windows, the 50% was showing the auto program « on » and the altitude was « off ». If I flip to the setting I saw RTH «on » and Altitude hold at « on ».
Is this setting supported ? can you support it in the future ? I only have a DX9.
Envoyé de mon iPad en utilisant Tapatalk
RTH + Altitude Hold in same channel does not work
Thomas, can you tell me if this is supported on the same channel, see my previous post?
I got a new spirit2 that is I in transit for a Goblin .buddy build and I would like to use the option on the same button, it’s they’re a difference between a uSpirit with a electric motor vs the Spirit2 ?
