Symmetrical pitch adjust sliders
jjuk
Next to the pitch range slider, can we get 2 new sliders that allow servo range correction specifically for symmetrical pitch, e.g. the range of all 3 collective servos is affected with a single slider.
2 sliders required for positive and negative.
This can be done already in the servo travel adjust screen, but you have to move all 3 sliders a few points each individually by clicking on them and using the arrow keys on the keyboard. It's time consuming and easy to mess up if you need these controls to fix a servo that's really moving further than the others. (E.g. the correct use for these sliders)
2 new sliders that adjust the collective servo throws next to the pitch range slider would be a real big time saver.
I know if mechanical setup is perfect this is not required - no matter how hard I try, I always end up with a delta of about 0.3 to 0.6 degrees (e.g. +11.0 -10.7).
A turn on my links is 1° so I cant adjust the links here.
With 2 new sliders, I can simply decrease the 11.0 to 10.7 (both are now 10.7), then increase the range slider so both are 11.0.
Or add a checkbox so the 3 existing servo travel adjust sliders can be moved at the same time.
Thanks.
we will add checkbox that will allow to move with all 3 sliders simultaneously similarly as for Subtrims.
This should resolve the problem.
I guess this will be in the next update.
jjuk
ZeXx86 wrote:Hello,
Thank you so much. This is a big frustration for me when setting up the heli after a crash.
jjuk
This doesn't seem to be in the 3.2 windows software. Is it still planned?
