Spirit RS with Spirit Jeti DS-12, HW4.1 no Tele Voltage
HFeda
Hello Tomas,
Configuration:
Spirit RS
Hobbywing: Platinum_HV_V4.1 Firmware: PL200-04012Vbar
Spirit Sender: Jeti DS-12
Telemetriedata:
I get 6 Values: but S_Voltage [V] is always 0 and S_RPM is always 0 and [without unit]
with old Firmware
Hobbywing: Platinum_HV_V4.1 Firmware: PL200-04011
I get 6 Values: S_Voltage [V] works correct and S_RPM is correct but always [without unit]
A unit for RPM would be nice to recognise the voice prompt of tele data easier
With Futaba integration it works at least with firmware PL200-04011 with PL200-04012Vbar I don't know.
vbar firmware should be used only with vbar. So you should not use this.
Can you describe problem with RPM please?
I dont understand it unfortunately.
HFeda
Hello Tomas,
thanks for your answer.
To the RPM problem:
For some telemetry values you get the unit.
For example for capacity you get the unit mAh
For current you get the unit A
But for s_rpm you get no unit.
When you configure rpm for speech output the sender tells you only the value without unit
so it is a little bit difficult to understand what the value means
So it would be nice to get for every temetry value the corespoding unit.
this issue is related to Spektrum. We cant affect voices or what is displayed in any way.
Our unit is sending just values. And it is then task for of the radio to process them.
HFeda
Hello Tomas,
but I do not have a Sprektum Sender.
I have the Spirit DS-12 sender.
So it would be nice when there would be the possibility to tell the unit.
I am sorry this was mistake. With JETI it should be possible. I think we can fix it.
HFeda
i have updated to 3.2.2.
with 3.2.1 it should be possible to get the unit for RPM.
JETI telemetry tweak:
S RPM parameter has RPM extension after value.
This can be usefull for voice speech output.
But i can only see the unit RPM now on the screen, but I can not hear the speech output for the RPM extension.
I use the german language.
Do I have to install an extra audio file for that speech output?
thx Manfred
