Rescue mode with Position and Altitude hold
Posted: Sat 27. Jun 2020 21:46:14
by AlexAusTelfs
Hi Folks,
as I recieved my Geolink I asked myself (maybe I am misunderstanding the basic functions) if the rescue mode can be combined with position or altitude hold.
Can this functions be combined or is position and altitude hold only available in "stabilisation mode"?
Thx a lot
Alex
Re: Rescue mode with Position and Altitude hold
Posted: Mon 29. Jun 2020 22:20:17
by AlexAusTelfs
No body any idea?
Alex
Posted: Mon 29. Jun 2020 22:25:42
these functions can be combined.
But with Rescue only Position Hold will work.
Also with Position Hold, Altitude Limit will work which is automatic Rescue mode.
Posted: Wed 01. Jul 2020 17:51:23
by AlexAusTelfs
Hello and thx first of all for the explanation.
OK in THAT case I am facing a problem:
If I activate position hold (in GEOLINK menu) and test it „on the ground“ the simulation shows „rescue mode active“ and „position hold active“.
But if I fly I can not control the pitch. Even if I set pitch „override“ to maximum.
Pitch is simply not controllable and the heli flies off and is climbing (also not activating hover pitch after the set 2s time limit).
Altitude hold is NOT activated.
Alex
Posted: Wed 01. Jul 2020 19:52:03
by buttles
Rescue active will override any pitch commands. It's the bit that climbs the Heli until you switch it off. I re-read Tomas' post above and it's in there. Hopefully I've got that right :?:
Posted: Wed 01. Jul 2020 22:31:57
by Galuwen
Hi Folks,
I am sorry no not really: For the first "rescue phase" of course. But after the set limit of time rescue switches to the second and lower "hover pitch" and heli stops climbing.
Thus works perfectly on my heli in normal rescue mode.
But with position hold active (should have nothing todo with pitch) the feature above does NOT work anymore and heli remains endless in maximum rescue pitch w/o any possibilty of manual override (what is possible with position hold of).
Alex
Gesendet von meinem SM-G955F mit Tapatalk
