[SOLVED] After Crash Spirit Pro is not working
thgeisel
After a crash I took the Spirit Pro from the crashed heli and moved it to a new one.
Evry thing is working fine , I can bind it to the transmitter , I can access the Unit with the program, the servos move with the sticks of the transmitter.
Only when I turn or move the heli, there are no reaktions as usual. None of the servos shows any reaktion.
Is there anything I can do to repair it ??
yes, I believe it is possible.
Please send me private message with Serial number you can see in the Connection tab.
Then we can check where the problem can be.
Thank you.
