Srxl2 expansion
mattinflorence
Would like to see the expansion of using the srxl2 stuff (4650 / 4651t) to be able to use them in the sat ports.
Just like when using the 4649t, that's connected to the Aileron pin for signal and can also use sats.
So would like to be able to connect a 4650 or 4651t normally with the Ailerson pin, then connect another to the sat port/ports, thus not needing to use the ar6610t receiver.
parkplatzflieger
Did you have problems with the 4651t? I use it with Logo 600SX and Voodoo 600. The quality of the signal is better than before i am using ar9030 with two sats. Why do you think the situation is better with one additional (oldschool) DSMX sat?
mattinflorence
Ultimately, I'd love to have the ability to run dual 4650 or 4651t sats at the same time for redundancy. Even more so in my large scale builds. While I'm okay running a single one in anything 500 size and smaller, I'd prefer to run 2 on anything larger.
We are working on support for two satellites.
mattinflorence
:D :D :D
