Does Spirit RS supports ESC Kolibri 140 telemetry data?
schmeckm
Hi All
Does the Spirit RS Support telemetry data from the kontronik Kolibri 140 ESC?
On the spirit homepage the Kolibri ESC is not listed.
http://manual.spirit-system.com/index.p ... _telemetry
buttles
I don't know the exact answer to that but be aware the Spirit Telme doesn't report BEC voltage or Current. On my Kosmik anyway through Jeti.
It may if you use the other cable? Hoping Tomas can say if it could be made available....!
mchnb003
My Jeti Mezon isnt listed either, but works perfectly nice.
I would assume - as the Kolibri does support multiple protocolls - that it will work with the Spirit. I even can use the Kolibri data on my quite outdated skookum SK720BE
actually it is listed as supported:
buttles
ZeXx86 wrote:Hello,
Check your specific Radio as there is a variance on what each will report
Yes, but all will report same data.
Jeti has built in BEC voltage measurement so there it will not report dirsctly from ESC. In this way telemetry can be sped up.
buttles
ZeXx86 wrote:Yes, but all will report same data.
Sorry to take the OP's thread sideways but they need to be sure they will get what they expect. I will open my own thread on this.
