Tail gyro HH
alex4orly
How do I set the HH in Sprit Pro?
I did all the wizard steps already
Yesterday is history, Today is a present, Tomorrow... a dream.
urgno
if TX gyro gain is -100 to +100
from -100 to 0 is normal tail
from 0 to +100 is hh tail
if TX gyro gain is 0 to 100
from 0 to 50 is normal tail
from 51 to 100 is hh tail
alex4orly
urgno wrote:if TX gyro gain is -100 to +100
Oh, I see - I know that.
I thought there is a way to set that in Spirit
Cheers
Luv2fly2
I must have miss read the instructions, I understood this to be for the head gain. I too am trying to find how to setup the tail or being to adjust it alone and not the head at the same time. I am switching from Axon and you have two channels for gyro 1 head and 2 tail. Is this not the same ?
No it is not the same.
Gyro Gain (for tail) is by default assigned at Channel 5. Just like the most other gyros.
Cyclic Gain is configured in the unit, default settings will work almost in all cases. So no need to change it from default usually.
But eventually you can assign the Cyclic Gain for a dedicated channel too.
But Gyro Gain is always only for Tail controlled by a single channel. Never two things mixed in one channel. This would not work too well.
