Setup Wizard / Diabolo and Warp360
Franky13
Hello!
I fly a Warp360 and Diabolo.
In the Setup Wizard (step 4) I can select various helicopters. What is changed there exactly?
Which is similar to the Warp or Diabolo?
Do I have the Warp, Diabolo make special settings in the Spirit?
Thanks!
Greetings Frank
you can use Default preset that will work fine for both helicopters.
Main difference between such presets are in the rudder settings, especially Piro consistency parameter that is variable across each helicopter. Smaller helicopters will work well with values around 160 while bigger ones with value around 170-185.
Also for bigger helicopters you mostly want to set Gyro gain multiplier to approx. 1.3x because with 1.0x rudder gain in transmitter even with 100% could be not enough.
If you use faster rudder servos you should set Rudder Delay to 5 - 10. For Brushless or extremely fast servos I recommend value of 0.
Other parameters are not so important for ideal performance and default settings will work in most cases very well.
ajbwn
Franky13 wrote:Hello!
Thanks!
Greetings Frank
Hi i have one on my Warp 360 during setup i selected Logo 400 in the drop down menu and with a couple of minor adjustments it fly’s fantastic, previously i have tried the Warp on a Brian and a Beast X but the Spirit is defiantly the way to go.
Regards Alan
