Setting Castle ESC endpoints with Spirit (RS) and Jeti
Posted: Sun 12. Jul 2020 20:49:57
Two weeks ago I had a problem with getting a reliable spin-up of my new Goblin 770 with CC Phoenix Edge HV 120 ESC (Set RPM Gov mode), 12S, Spirit RS and Jeti DS-12. I didn't fix it (yet) but in trying, my multiple 'factory resets' and settings changes in the ESC have now lost the endpoint settings and I'm having a hell of a time trying to re-set them and move on to the actual problem!
Seeing other threads on the 'Helifreak' forum about autorotation bailout issues has led me to (perhaps) a possible explanation in that the Spirit doesn't 'release' a low throttle point until after it has booted-up, and the CC ESC somehow doesn't pick it up. By now I'm well-familiar with the Castle recommended endpoint setting procedure and then (if successful) setting-up the Castle governor for 'Set-RPM'. The issue is that when 'opening up' the endpoints for the ESC to recognise, it doesn't, and I think it's due to the relationship between the FBL unit and the ESC.
I have a spare REX3 receiver and with a battery and connecting the ESC directly, I have set the endpoints but when connecting back to the Spirit, the ESC won't arm at zero throttle (i.e. with throttle-cut switch on). I have also pre-powered the Spirit to get it initialised and then connected main power to the ESC, but no progress: it won't initialise (arm). Throttle curve is set to 0-50-100 for this process.
It's tricky to know where to pose the question: is it a Spirit, Jeti or Castle Creations issue? I'm here because I could do with help understanding the Jeti / Spirit throttle range inconsistencies. Specifically:
1. If the Spirit requires 1100uS - 1900uS range, do I set throttle range in the transmitter to match this, even though the 'Diagnostic' tab shows less than 0-100%? Or, do I then alter the throttle range in the 'General' tab to get me back to 0-100% on the 'diagnostic' tab?
2. If I set the endpoints first with a separate receiver, how do I get the Spirit to recognise the same range?
I didn't have the problem when setting-up with a Spektrum iX12 transmitter, so I think it's related to the Jeti DSthrottle range.
Eventually, if I can get past this I can try again at fixing the ESC/Governor issue!
Cheers, Andy
UK
Cheers, Andy
UK
