Master and Slave from Kosmik 200 to the Spirit?
Franky13
Hello!
How do I connect best master and slave from Kosmik 200 to the Spirit? As a receiver, I have the Jeti RSat2. There I've only PPM and Ext. Connector for telemetry.
Thank You!
Greetings Frank
taosgraveyard
Franky13 wrote:Hello!
Thank You!
Greetings Frank
You can wire one of your servos into a short y connector and plug the slave into the other end of the Y
Or you could do the same with the PPM lead from the RX
Franky13
OK,
So I put a y-cable in ppm from the RSat2. then the plug from a y-cable to slave from Kosmik, the other plug from the y-cable to RUD on Spirit ...
And the master cable from Kosmik to AUX from the spirit ...
is that correct?
RUD - Y-cable:
- PPM
- BEC SLAVE
AUX - THRO, BEC MASTER
This could be the best solution with one Y-cable. But be sure Y-cable can handle such current (approx 10A).
