YGE Telemetry Not showing up with Jeti R7 Nano
rediary
Hello again!
This is probably a very specialized question, but i could use some help. I am attempting to get telemetry to show up from my YGE 35A-LVT to my Jeti DS-12 transmitter via the uSpirit and a R7 Nano RX. I have HobbyWing telemetry enabled and working on four of my other Helis so i am familiar with the process, but this seems to be eluding me.
+ The YGE is updated to the latest firmware
+ The YGE has been configured using the USB programming box and set to Jeti Telemetry
+ I'm plugging the blue YGE cable into the Sat port on the uSpirit using a micro jst adapter. I have disconnected the red wire from the adapter.
+ I have set the telemetry type to YGE in the Spirit Settings
+ The transmitter automatically detects that there are telemetry values available, but there is no data, they all read "0".
I have asked for help from YGE and they have instructed me to connect the ESC telemetry cable directly to the Jeti receiver. Is this necessary? Can I not just connect via Spirit and send over the Telemetry values via the FBL?
first from all there are two possiblities how you can connect this ESC.
1) Directly to the receiver - no Spirit unit is utilized
2) Directly to the Spirit unit - no telemetry connection with receiver.
You have to decide which one you want. With first option there is no relation to Spirit.
rediary
Thank you for the reply, yes i was attempting to go with option 2). Directly into Spirit.
Based on my list of thing's i've tried in the first post, Is there something i'm missing on how to get telemetry to show up?
TomasN
Problem is that you set Jeti telemetry in the YGE. This would be ok if you connect ESC directly to receiver. When you connect it to the Spirit you have to use default (YGE) telemetry in ESC.
yufasa
Oh damn!
rediary
That did the trick! It works! Thank you so much :)
