logviewer.lua
Storchy
How can i change to the current flight, there is always the previous flight
You have to access the log again, then it will be from current flight. Probably something bad is happening each flight, for this reason you can see saved log from previous flight.
Storchy
no it was always the same previous log because it was always 490s long.
I have tried it to read it with the computer
spirit-log-2020-08-01-133415.pdf
(71.11 KiB) Downloaded 80 times
now it is cleared and i see the current flight
Thanks a lot
(71.11 KiB) Downloaded 61 times
Oh, you have to read/load it completely in your radio.
Only then it will be erased.
Storchy
Thanks for the tip i will try it next time
