GeoLink set home position problem
Posted: Thu 30. Jul 2020 20:22:00
Today, I updated my Spirit 'Red' and My Geolink to the latest 3.1 version.
When the Geolink is powered up, the blue led lights up, then goes off, then after 5-10 secs, it turns permanently on blue. This afaik indicates that it has sat lock.
Then I set the home position:
I flicked the switch to "on 2". The swash moves slowly from low to high, then jerks back to low, indicating the home position is set.
After doing this, I have no control input, nothing, cannot arm, cannot move swash, cannot move rudder. All inputs seem to be ignored by the spirit.
I have to unplug the battery and reconnect it to regain control, then set home position again. This time, it responded to control inputs as expected, so i set home again, and then it stopped responding to all inputs again.
I can reproduce this issue every time.
Power up, wait for solid blue led.
Set home position.
if control inputs work, set home again, and after its done, there will be no response to control inputs.
--- 2nd Issue ---
After landing, the elevator is twitching. Random movements. All other servos are perfectly still, but the elevator is randomly flicking up and down every few seconds.
Before the update, i was using v2.8. I have not had any of these issues with v2.8. After setting RTH position exactly as described above, the unit responded to all control inputs exactly as expected.
Set home position.
--- 2nd Issue ---
