Governor feature and Reciver
muadib_at
Hello!
I have on question. When the governor Feature will come in feature releases, can i use it with a normal reciver or must I use a Satelite?
Because the throttle is conectet to the reciver.
And where will the RPM sensor be connected?
thanks Andreas
governor feature should be available very soon.
All necessary information will be described in the manual and this forum, so stay tuned.
But generally ESC with built-in RPM output will be the best choice.
PWM connection will be only one, that is not supported for Governor operation. All other should work.
