Android Spirit Settings Bank switching
weixelgeist
Hi
I am on Android Spirit Settings 3.1.0 with Wifi-Link
I cannot find out how to switch the Banks, the app is always on Bank0
Thank you, Gerhard
It is enough to swipe the screen to the right side.
weixelgeist
It works, thank you.
Another question:
I have set the Wifi-Link Modul to 60sec Auto Switch Off
But the modul does not switch off.
You have to disconnect from the module.
If you have set up also Wifi Client then you have to disconnect client - or go away from the AP.
weixelgeist
Ok, I got it.
Thank you
amelin@macks.be
I have the same problem, not able to change bank !
Android on One T 7 plus.
Swiping to the right, up, down or left, there is no swipe possible.
Swipe what ? All screen ? Just a specific place of the screen ?
Thanks for help.
JoergZ
it is an old task but i have today the same irritation...
I had the same problem of being able to view the banks by swiping to the right.
Navigating by swiping was enabled on my ONE+. This reliably prevents this menu function from 'Spirit-Settings'.
I switched to 'navigation via symbols' and then >swiping from left to right< is working and i am able to select Banks...
New phones no longer have navigation icons. Please show an info about it. Perhaps also simplify switching B0/B1/B2 via fixed icons in the upper area.
Greetings
no buttons are needed to access the menu.
You only need one finger - put it at the left side, center of the screen and then move to right. This will open the menu.
