Return to lift off position
stefaanbolle
GeoLink - New Return to Home feature:
When configuring channel value to 50% for F: GeoLink - Return to Home new feature is engaged. State (4)
Model will return to a Lift Off position.
Lift Off position is automatically programmed any time model is not flying.
Lift Off position is independent from programmed Home spot and is stored in a volatile memory.
Pilot do not have to program any spot and do not have to care about changing field.
Original RTH feature is unchanged and can be utilized complementary.
Do you configure 50% in the digital switch setting in the transmitter?
If so is it possible to configure a 3-pos switch so you do not use the programming mode like
pos 0 is off
pos 1 = 50% lift off RTH
pos 2 = 100% pre-programmed RTH
or is this a wrong assumption?
yes, it is perfectly correct.
You can program it like this.
stefaanbolle
Thanks! Is it possible that diagnostic screen does not reflect those values
Bill-kraken-700
HI on the settings on (4) says return to power up point ? can any one verify if this setting will return to where heli takes of return to where it was powered on ?
Bill-kraken-700
ZeXx86 wrote:Hello,
Can you clarify whether it’s the power up point as stated in software or if it’s the take off point as stated in the manual?
