Solved Pitch range changes
morrchew
I have set up many Spirits and this one has me beat I set up all parameters in the setup to 12 degrees + and - . 6 degrees is good and I do get 12 degrees when wizard is open I saved all settings . Power of heli, power on heli set stick to positive pitch and I get 15 degrees positive 15 Negative what’s wrong . Plug spirit back into USB and all is 12 degrees .why is it changing . This is Spirit v2 and 2.8.0 firmware . I have 23 spirits and all other Helis work fine . What do I look for or is the unit faulty it’s A new unit and first install
On a Goblin Urukay three blade .
very likely you have multiple banks. And you configured unit only in the Bank 0. When Spirit Settings is opened, then Bank 0 is selected automatically. So it is enough to set other banks in the same way - especially Collective Pitch range - see Bank Comparison.
