[SOLVED] Spirit pro with govenor and spectrum multi adapter
mb-1953
Just checking to be sure that I am going in the right direction. I am using a Hobby wing rpm sensor which I am powering at 3.3volts from the sat port. The sensor output is being connected to the pit terminal of the ele/pit,ail port. I am using the multi adapter to connect 2 sats, the single wire of the multi adapter connects to the ail pin of the same port.
Can they work together?
yes, looks good.
mb-1953
Thank you, Tomas.
