[SOLVED] Wrong speed with the Spirit RS, wrong values THR
heli_5200
Hello, I have switched my Heli Spirit Pro to the Spirit RS 1 to 1.
flown with it today the speeds of the main rotor are no longer correct.
It is due to the gas duct of the Spirit RS.
From the transmitter 1.0ms - 2.0ms come from the THR only 1.1ms - 1.9ms.
Why is that?
That doesn't make sense, does it?
Greetings heli
That is correct behavior. The most ESCs are using Throttle Range 1100 to 1900us.
With this you do not have to calibrate ESC, because range is already correct out of the box.
If you need to change behavior, simply enter different values in the Throttle Range Min. and Max.
heli_5200
Hello ZeXx86,
where should I set the values?
In the transmitter or in Spirit RS?
greeting
In the Spirit unit. It can be configured from radio, smart device or from computer.
