Hello, I converted my Goblin 420 from BeastX to Spirit 2.
I've got all the pitches setup using the Spirit windows app.
0 degrees, level swash at mid stick, but when I go full positive or full negative, the pitch is not the same.
For example:
+12.5* top stick
0* at midstick
-13.7 bottom stick
If I bring the settings down to make bottom stick less pitch, it brings down the positive pitch value as well.
For example:
+11.3*
0*
-12.5*
Is there a software setting for the Spirit to limit the travel for positive or negative only or do I use the travel settings in the transmitter?
Uneven collective pitch range
Have a look here....http://manual.spirit-system.com/index.p ... tive_Pitch
