Align esc BL80A telemetry with spirit pro not working
joesta
Can someone please help, Ive followed instructions on connecting uni cable to futaba sbus2 port and red wire to ele/ail port. Brown and orange to rud port and I got no telemtry, no control of servo. Please help. Im using Align BL80A esc, futaba 16sz transmitter and futaba 7008sb receiver. If someone can help. I've spent all day trying different ways of connection and no good.
please check this page:
Then do not forget to add additional cable for powering the receiver. For example between CH1 port (RX) and AUX2 (Spirit) port.
joesta
Hi, tried connecting normal servo wire from 8sb(rx) to aux (unit) also ch1 ( rx) to aux (unit) still no good. Im running 3.4.1 firmware on unit. Does that matter at all? Also I have external bec that I plugged into rx, would that interfere?
first it is needed to make Futaba telemetry to work.
So that you will see at least telemetry values from Spirit - vibrations/RPM.
Is this the case?
Then you can continue with ESC Telemetry. Please note ESC must be updated to the latest firmware (but not for VBAR).
joesta
I'm lost. Cause I followed everything for futaba telemetry setup as per spirit instructions. But when I connect the uni wires (red in ele/ail/pit) brown and yellow in rud port of unit it doesnt even move my servos. Its only when I change the yellow with red that I can get movent of servos, but still no telemetry.
joesta
Any chance of making a video or photo instructions on this? Cause that would help alot of people.
Telem UNI wire shouldn't be connected at the ELE/PIT/AIL.
It should be connected at the SAT port.
You are doing two different things:
1. Futaba Telemetry
2. HobbyWing ESC telemetry
First from all Futaba telemetry must work. For this you do not need ESC or Telem UNI.
I recommend to make it work first. Then HobbyWing telemetry will be easy.
joesta
Ok. How do I make futaba telemetry work? Do I need sensors bought separatly? Or do I follow instruction on spirit system website that says (To make futaba telemetry work, you need frysky integration cable........) Cause thats what I did and when I plugged the integration cable in after modification instructed from spirit guide for futaba, I got no telemetry and no movement from servo.
buttles
ZeXx86 wrote:Hello,
1. Futaba Telemetry
Just check that info Tomas, Step 3, Wiring has the split cable going into the last two ports??
And is the Align ESC actually supported?!
You need to just proceed according Futaba Telemetry guide. Nothing more is needed. For now please forget about your ESC. Without Futaba Telemetry working, the rest is meaningless.
Yes, you absolutely need FrSky integration cable with a small modification as described in the Futaba Telemetry guide.
