[SOLVED] Castle Creations Phoenix Edge HV 80A
latjo-k
Hi
A couple of questions abaout this esc,i plan to use the governor in spirit unit the white cable from cc goes to the
pit pin in unit ok.But the manual says connect a resistor 10Kohm betwen the white and the red cable for use
telemetry?Else use the telem cc cable?I can only se brown red orange on this cable and a shrinktube in the middle.
I cant understand this?
Can anybody explain?
//Latjo
red and orange wires are same as white and red.
Pit cable is for rpm sensing for governor. It is 4th wire. And also there is secondary bec cable.
Anyway we highly recommend to get telem cc cable.
latjo-k
Ok
I order a telem cc cable,whth that the white cable connects direct to the pit pin(for rpm)and the throttle cable
connects to telem cc cable and the telem cc csble goes to Trottle on spirit rs unit?
am i correct?
//Latjo
latjo-k
hi
The telem cc cable is on backorder?
//Latjo
Yes, you are correct. Yes, cable is not in stock, but we will produce them within 1-3 days.
latjo-k
ZeXx86 wrote:Hi,
HI
Is it then ok to put the 10Kohm resistor between the red and orange cable?
//Latjo
Yes, this is OK if done properly.
latjo-k
ZeXx86 wrote:Yes, this is OK if done properly.
OK
Thank you Thomas
latjo-k
Hi
The esc is up and running,difficult to get it to arm,find a video on web.
Governor working ok and telemetry displays all data as it should.
//Latjo
