[SOLVED] Rescue + RTH - will make heli go up non stop
Pking
I have a Spirit 2 using SRXL2 with Geolink + IX12
I have enough channels to turn on different control rescue and RTH.
RTH turned on, heli goes at the right spot
Rescue is on a toggle switch and will go up and after the delay, controls are given back.
When i turn on RTH and toggle rescue, the Heli will go up and never stop until i turn off rescue. did wait the timeout and tried it a few times with the same results.
Here are the config file.
2.4ds
Bank 2
(255 Bytes) Downloaded 162 times
1.4ds
Bank 1
(255 Bytes) Downloaded 146 times
0.4ds
Bank 0
(255 Bytes) Downloaded 155 times
Pking
Hi Thomas,
What should I expect in terms of follow up on this issue ?
Is it considered at least a bug and can you correct it? A answer will be appreciated.
LogoX2
I can confirm that this does the same thing for me. The Rescue time out does NOT work when RTH is active !! Heli just keeps going up.
Pking
LogoX2 wrote:I can confirm that this does the same thing for me. The Rescue time out does NOT work when RTH is active !! Heli just keeps going up.
Thanks LogoX2 for confirming the issue.
Thomas,
Can i know when you expect to look at this issue ? Is this thread the right place to post a bug ? I usually see you answer and i see nothing posted so it is getting me nervous about being seen and addressed.
I am not replying, because we are extremely busy.
Once I will be able to answer the question I will reply.
Thank you for understanding.
Unfortunately everybody expect reply as soon as possible. But to reply hundreds of questions each day is taking time.. My primary goal is to move development forward.
Pking
Thanks Thomas !
The issue will be resolved in upcoming firmware update.
It will be available within 1-2 weeks.
Pking
Thank you very much Thomas !
Pking
ZeXx86 wrote:The issue will be resolved in upcoming firmware update.
I tested both features at the same time and now, the rescue stops after the timeout in version 3.2. Problem solved !!
After a few test I pushed and had to use both and it worked, saved the heli...
Thanks Thomas
