Jeti icm Spirit (not pro)
Hermor
I received my new jeti-spirit ds12 today, really happy with it.
But i cant figure out, coming from frsky eacht sbus rx has 16ch over bus. What about jeti rx? dus is support 16ch over ex ppm?
And..is is possible to use spirit with only jeti ex sat?
gr Kees
Verstuurd vanaf mijn SM-A520F met Tapatalk
our DS12 has 16 channels out of the box.
It can work with many protocols, but EX BUS is the best and allow full telemetry.
If you have Spirit RS you can connect to it with no additional receiver. It has everything included.
For other Spirit units you will need external receiver. Any JETI DUPLEX receiver will work. For example REX3 should be fine.
Hermor
Tnx, iam not familiar with jeti,
Does that mean the ppm signal line supports 16ch? and is it possible to control btw landing gear by one if the phisical servo outputs?
Yes,
why you are interested in PPM? It is unused in the most cases.
You can connect landing gear also directly to the Spirit RS.
Hermor
Hoi,
i asked because i wanted for sure the REX series have 16ch over EX bus, Not specially the pmm is interesting me.
I ordered a REX3 and some REX7 lets see how it works.
tnx for helping!
