Spirit FBL 2- DS 12 no sound while connection the Sender
schmeckm
Hi ALL
Do you know why I got not over the Jeti a signal back that my Spirit 2 is conneced with the DS12 Jeti Sender?
Ij I connect a Jeti Receiver for my other planes or Jeti if have not a FBL2 installed I got the sound back.
Markus
yufasa
Are you talking about the RS unit as that has a receiver?
Not sure how a Spirit 2 will impact that...
schmeckm
Dear ALL
I bought directly after you have launched the SPIRIT RS with the Jeti Receiver included. This week I included the RS into my new Goblin 570 Kraken but I have some serious issues.
Yesterday I wanted to do my maiden flight and I have the following issues. It was good that my Heli was on ground and in the pre-flight check mode.
Issue 1: If I connect the battery to boot up the FBL there is no sound raised “Receiver connected” like by the normal other Jeti Receivers. If I switch off the transmitter, the Heli goes in Fail modus and into the positins I have defined in the FBL Software. If I switch on the Heli than the sound is coming, “Receiver connected”
Why is this not coming up when booting up the Heli?
Issue 2: It seems that Basic Telemetry data are not transmitted such as signal strengths like by my other Jeti Receivers?
Why is this ot transmitted? I thought it was a normal Jeti receiver included.
Issue 3: If I boot up my Heli and built up connection to the battery, sometimes I have the serious behavior that the Heli is not reacting anymore although he was normally boot. It occurs after 1-2 min after booting the FBL. After FBL Boot up I can move all my sticks for the pre-flight checks but after a while the heli goes like in Fail modus and is not reacting anymore. I can see that the Heli is still fully powered up and I can see that all Servos are fully powered
For me the issue 3 is a serious issue.
Have you faced this issue already?
Markus
HeliMLM
as Markus posted the same problem in jetiforum (or it is a funny coincidence with same name & problem ;)): it's a Spirit RS and not a Spirit 2 :)
in the other thread i've asked for: DS-12 version and firmware, Spirit RS integration files up to date, Spirit visible in device manager, trying a rebind, connected cables on the Spirit RS (what/where).
additional information Markus gave in the other thread: no basic telemetry as i.e. signal strength is shown on DS-12, connection getting lost after 1-2 minutes, Rx is visible in device manager, ...
{ooops... to late... Markus just posted the information himself}
cheers
Michael
Yes, he is posting the info everywhere, but not reading answers :(
