[SOLVED] Serious FBL Spririt RS Problems with my Kraken 570
schmeckm
Dear ALL,
I bought directly after you have launched the SPIRIT RS with the Jeti Receiver included. This week I included the RS into my new Goblin 570 Kraken but I have some serious issues. Yesterday I wanted to do my maiden flight and I have the following issues. It was good that my Heli was on ground and in the pre-flightcheck mode.
Issue 1: If I connect the battery to boot up the FBL there is no sound raised “Receiver connected” like by the normal other Jeti Receivers.If I switch off the transmitter, the Heli goes in Failure safe mode and into the positions I have defined in the FBL Software.  If I switch on the transmitter again the sound is coming,“Receiver connected”Why is this not coming up when booting up the Heli?
Issue 2: It seems that Basic Telemetry data are also not transmitted such as signal strengths like by my other Jeti Receivers? Why is this not transmitted? I thought it was a normal Jeti receiver included.
Issue 3: If I boot up my Heli and build up connection to the battery, sometimes I have the serious behavior that the Heli is not reacting anymore although he was normally booted. It occurs after 1-2 min after booting the FBL.  After FBL Boot up I can move all my sticks for the pre-flight checks, but after a while the Heli goes like in Failure safety mode and is not reacting anymore. I can see that the Heli is still fully powered up and Ic an see that all Servos are fully powered For me, issue 3 is a serious issue.
Have someone faced similar issues?
The entire Heli Setup was quite expensive.
I will not take the risk to fly with all those issues.
Markus
Please disconnect everything from E2 port. Then it will work all OK.
Probably you have some telemetry sensor there. This is wrong with Spirit RS.
schmeckm
Hi ALL
Yes thanks. Unfortunately this was the root cause of issue. I connected the Telemetry cable from my YGE Brunchless controller directly with the Port E2.
I have overseen it in the Docu-WIKI that this Channel can not be used.
It seems now its working fine, I'm l'm also getting a sound feedback message that the receiver is connected as expected.
Thanks, Markus
