Castle ESC RPM readings intermittent
Posted: Sun 20. Sep 2020 18:33:20
Today I flew my (trusty) Goblin 770 Sport and immediately noticed the RPM on spool-up and take-off kept climbing through the governed rpm to a maximum of about 2100rpm. The target rpm was 1500. In the hover I tried all 3 idle-up (Flight modes) but no change - the Spirit governor wasn't responding. I shut it down and the flight log confirmed a few lines with 'rpm sensor noisy' (or similar words)
Back on the bench with blades off the governed rpms tested ok. I looked at the rpm sensor test in Spirit Settings and while it shows the correct rpm when running, the 'indicator' for the sensor flickers intermittently, confirming the 'noisy' issue. I've attached a screenshot capturing one of the moments when the sensor is inactive but the rpm is showing a realistic figure (should be 1500). This is new to me, never happened before with this heli, so before I start stripping-out parts I'm hoping for some advice as to where to look / what the issue might be, please.
Setup: Goblin 770 Sport - (quite new, around 15-20 flights total, never crashed), 12S power. Castle Creations Phoenix Edge HV 120 ESC with Spirit Telem-CC cable in throttle-lead to Spirit RS, which is configured as-per Spirit manual along with the ESC to provide telemetry. Since the RPM telemetry is included with the throttle signal instead of a single-wire to the rpm sense-pin on the Spirit, I've no idea how to diagnose where the fault lies. There's no obvious signs of wire or connector damage and if there was, I'd think the throttle signal would be intermittent, which it isn't.
I've attached a screenshot of the relevant Governor settings page if it helps. Please note that early-on, I switched to the Spirit governor from the Castle governor because despite altering the ESC's settings, the initial spool-up included a big tail-kick which would rotate the heli about 90 degrees on the pad before take-off (!). This is why the 'spoolup rate' is set to 'slow'.
Any ideas, please? Many thanks,
Andy
UK
Andy
UK
