Spirit Pro Initialization Issue
Posted: Wed 23. Sep 2020 5:41:09
Good morning,
I have an issue with my Spirit Pro for which I have found no solution by searching the forum.
When the Spirit initializes the swashplate will „jump“ as usual but then in stead of being level after the initialization the swashplate tilts (full nick UP and roll LEFT). When I then disconnect the battery and reconnect the Spirit will initialize again and then the swashplate will stand perfectly level when initialized.
It normally happens when I power up my heli after it has been without power for some time.
This means that it happens normally when I power up for the first time. if I do several flights it usually does not happen again unless I make a break in between.
I have obviously never flown with with the tilted swashplate but when the Spirit is re-initialized it works perfectly fine and I have never had any issues in flight. Also rescue is working fine.
The behaviour is quite consistent and will happen on most flying days.
The log says „Cyclic Ring activated“ when it happens and after re-initialization the log is clean.
I use a Jeti RSat 2 receiver and have no other sensors installed.
I have a Hobbywing Platinum 100A V3 ESC with Fan but disconnecting the fan does not appear to do any difference.
Vibration levels are generally low, but as said the problem only happens at power up where the motor is not turning.
Any suggestions?
Klaus
Any suggestions?
Klaus
