Problem with swashplate leveling
Bjoern_ve
I need a little help from you. I made a video of my problem.
https://www.youtube.com/watch?v=kpMt-BQYLmE
Description of the problem: When I make inputs on aileron and elevator do while the engine is off, the swashplate moves back into neutral. If the engine is running then it keeps its status and does not return to neutral. Is this normal?
I could find no vibrations.
Someone an idea, or is that correct?
Greeting Bjoern
Gaui X3, Gaui X7
this is very normal behavior of our FBL system.
It is working exactly as it should.
Behavior in "the flight" and on the ground is different.
Bjoern_ve
but how does the FBL detect the motor is running, because that makes a difference.
Björn
Gaui X3, Gaui X7
It is determined by vibrations which are always present on any model with rotating parts.
Don't be afraid, it will work fine.
Bjoern_ve
Thanks for the quick help.
Gaui X3, Gaui X7
Bjoern_ve
This video is a difference in behavior. The swash plate returns to its original position during the motor is running. Is there something wrong with the FBL?
Björn
Gaui X3, Gaui X7
This is normal if vibrations without blades are very low so it is recognized as if your model is not in the air.
With blades there should be higher vibrations so then the swashplate will behave little bit differently.
